hi
i need to show a calculated field number field with one decimal.
float result
result = aux1 + aux2 +aux3+ aux4+ aux5;
return result:
but always shows me an integer number.
I cannot properly test this at the moment but this may work. I made some changes and I added a "format" block at the end. Please try this out and report back any issues –
<!-- @@Formula: double result=0; Object btn1 = issue.get("customfield_12128"); Object btn2 = issue.get("customfield_12129"); Object btn3 = issue.get("customfield_12130"); double aux1 = 0; double aux2 = 0; double aux3 = 0; if( btn1 != null && btn1.toString().equals( "De 1 a 2 areas/ usuarios" ) ) { aux1 = 0.5; } if( btn1 != null && btn1.toString().equals( "De 3 a 5 áreas /usuarios" ) ) { aux1 = 2.0; } if( btn1 != null && btn1.toString().equals( "De 6 a más" ) ) { aux1 = 3.0; } if( btn2 != null && btn2.toString().equals( "Interno" ) ) { aux2 = 0.5; } if( btn2 != null && btn2.toString().equals( "Externo" ) ) { aux2 = 2.0; } if( btn3 != null && btn3.toString().equals( "PolÃtica" ) ) { aux3 = 2.0; } if( btn3 != null && btn3.toString().equals( "Reglamento" ) ) { aux3 = 2.0; } if( btn3 != null && btn3.toString().equals( "Circular" ) ) { aux3 = 1.0; } if( btn3 != null && btn3.toString().equals( "Doc. Corp. / Man. usuario / Metodologia" ) ) { aux3 = 0.5; } result = aux1 + aux2 +aux3; return result; --> <!-- @@Format: numberTool.format('0.0', value) -->
Add-on documentation here – https://innovalog.atlassian.net/wiki/display/JMCF/JIRA+Misc+Custom+Fields
<!-- @@Format: numberTool.format("0.0", value) -->
you should use the double quote marks in stead of the single ones
<!-- @@Formula:
float result=0;
float aux1 = 0;
float aux2 = 0;
float aux3 = 0;
if( btn1 != null && btn1.toString().equals( "De 1 a 2 areas/ usuarios" ) ) { aux1 = 1/2; }
if( btn1 != null && btn1.toString().equals( "De 3 a 5 áreas /usuarios" ) ) { aux1 = 2; }
if( btn1 != null && btn1.toString().equals( "De 6 a más" ) ) { aux1 = 3; }
if( btn2 != null && btn2.toString().equals( "Interno" ) ) { aux2 = 1/2; }
if( btn2 != null && btn2.toString().equals( "Externo" ) ) { aux2 = 2; }
if( btn3 != null && btn3.toString().equals( "PolÃtica" ) ) { aux3 = 2; }
if( btn3 != null && btn3.toString().equals( "Reglamento" ) ) { aux3 = 2; }
if( btn3 != null && btn3.toString().equals( "Circular" ) ) { aux3 = 1; }
if( btn3 != null && btn3.toString().equals( "Doc. Corp. / Man. usuario / Metodologia" ) ) { aux3 = 1/2; }
return result;
help please
Can you post us the entire script?
What add-ons are you using to do the scripting?
Help us plant more trees
