I see the Jira tool can be used within a recruitment process once a hiring search is underway, however can the tool be used to initiate a new hire recruitment requisition request with a form and have the requisition form flow through with to different parties for are required to approve the requisition?
Hi Sharon - Welcome to the Atlassian Community!
You can absolutely do that using a Jira Work Management project. Start with the Recruitment template as Jack suggests and then you can modify the workflow as needed to reflect your actual process.
You can certainly create a workflow for this. I actually use JSM in conjunction with JWM for this. JSM is used by HR for new staffing requests and JWM is linked in for on/off boarding.
Hi @Sharon T this article could be helpful for you https://community.atlassian.com/t5/Jira-Software-articles/Efficient-Recruitment-business-process-using-Jira-and-Business/ba-p/1847885
Regard
Register now
