can i change my project type Next gen to scrum
koteswararao
i want to change my project type Next Gen to Scrum type still my sprints are not started
Petter Gonçalves
March 28, 2019
Hello Koteswararao,
I hope you are having a nice day.
Unfortunately, there is no way to change your project to a different type, however, you can easily migrate your Next-gen issues to a classic project by following the steps below:
  1. Click your Jira icon () to navigate to the Jira home page.
  2. Select Issue and filters.
  3. Select All issues.
  4. Click the Project filter, and select the project you want to migrate from.
    (If you're looking at the Advanced mode, you'll need to select Basic)
  5. In the top-right corner, select more (•••) > Bulk change all.
  6. Select the issues you want to migrate and hit Next.
  7. Select Move Issues and hit Next.
  8. On the Select Projects and Issue Types screen, you'll need to select where the issues from your old project will go. Select a destination project and issue type, and hit Next. This is the issue type that each issue in your old project will become in the new project.
  9. On the Map Status for Target Project screen, select a destination status for each status in your old project. This is the status that each issue in your next-gen project will take on in the new project.
  10. On the final screen, click Confirm.
P.S: The only thing to keep in mind when you migrate your issues from a next-gen project to a Classic Scrum project is that reports data won't be saved, although it will not be relevant if have not configured your Sprints yet.
-  Migrate between next-gen and classic projects
Let me know if this information helps.
