can there be multiple workflows in a project. Ie. If there is epic which is around UAT only, can the
koteswararao
January 8, 2019
can there be multiple workflows in a project. Ie. If there is epic which is around UAT only, can there be a testing only workflow rather than going through development to test
Nir Haimov
Each project have multiple issue types (Epic, Story, Task, Bug, etc...)
You can set different wrokflow for aech type if that is what you want.
But you can't set 2 different workflow for the same issue type based on some data in the issue.
Leo
Hi @koteswararao,
I'm not sure I understood your question correctly
but yes, you can have separate workflow for each issue type
e.g. Task --> Workflow for Task
       Epic --> workflow for Epic
Refer this page for more details: https://confluence.atlassian.com/adminjiraserver073/configuring-workflow-schemes-861253569.html
-Leo
