I would like to do queries on the raw jira data associated with our jira on-demand instance. Is that possible?
No, you won't get access to the database, it's not supported.
Ok. thank you. I do custom reporting and it takes a lot of time putting these together and was hoping to build my own so I could add drill downs.
