change default branch name in jira
todesco
We have integrated JIRA ondemand with bitbucket and love the fact that you can create a new feature branch from an issue. What we'd like is to change the default value of the branch name field to something lite "feature/<issue-key><issuename>".
Couldn't find an option to do that. Is it possible?
Br
Joakim
3 votes
Justen Stepka [Atlassian]
Hi there, this is an error on our part.
The branch types attribute is only available for Stash when using the new Create Branch feature that is supported by Bitbucket. Inside of JIRA we currently have a general 'What's new' page that is the same for behind the firewall and OnDemand.
I'll check with our JIRA team to see if we can get this fixed, sorry for any confusion this has caused.
Cheers, Justen -- Bitbucket product manager
Chris Knight
August 19, 2014
Is there an update for this? Been almost a year now. If this has been done can you point me to where the documentation is as I can't seem to get this working.
danielsheard November 17, 2015
Now 2 years! This is a basic change and very critical to improving the efficiency of the tools
guisim
March 4, 2016
I'd love to have some flexibility regarding the branch names in Bitbucket. Any updates?
Shea Martin September 22, 2016
Update?
Ádám Zovits August 15, 2017
An implementation would be a nice way to celebrate the 4th anniversary of this feature request :)
Ádám Zovits September 14, 2018
Or maybe the fifth then :D
Anatoliy Mushtuk
December 3, 2018
Please, implement configurable branch name prefix! Such a simple feature would bring a good value for our team.
Abdul
September 5, 2019
almost 2020.
Soheil Hasankhani
March 28, 2020
2020 :|
Bernd Eckstein
April 7, 2020
I was just searching for this feature, as i was advising a team how to use bitbucket with jira and git flow ... and guess what: they ALL forget to select the feature/ prefix.
I would LOVE to select a default branch type based on the jiira issue type.
Noah Fernandes
April 9, 2020
How the *beep* is this still an issue 7 years later?! C'mon Jira, what the *beep'* is taking so long?
Aleksey Khokhlov
March 21, 2021
2021 Maybe in this year?
Like Phil Rittenhouse likes this
8 votes
todesco
To follow up on my own question. In the "What's new in JIRA 6.1" dialog that pops up when you enter ondemand there seems to have been added an option "branch type" which would solve my problem. But we don't get that option in our system. Is this not rolled out yet or do we have to configure it?
Ian Molee
October 24, 2016
We'd love to see this as well. Our default branch naming scheme includes the year and month the branch was cut.
4 votes
Jason Allen
February 22, 2017
Hello
Hopefully this will be of use to some people. I am a fan of Tampermonkey scripts to tamper with websites to do what I want. In a need for this feature I have implemented this short script:
// ==UserScript==
// @name         Bitbucket: Better branch name
// @namespace    https://www.playitsoftware.com
// @version      1.0
// @author       You
// @match        https://bitbucket.org/branch/create*
// @grant        none
// ==/UserScript==
(function() {
    'use strict';
    var issueType = (window.location.href.match(/&amp;issueType=([^&amp;]+)&amp;/) || [])[1];
    var prefix = '';
    switch(issueType)
        case 'Bug': prefix = 'fix/'; break;
        default: prefix = 'feature/'; break;
    $('#id_branch_name').val(prefix + $('#id_branch_name').val()).trigger('change');
It pulls the issueType from the href and prepends the appropriate prefix to the branch name. Feel free to tweak for our own prefixing needs.
Jason
Benedict Roeser July 25, 2018
Hey Jason,
This is in fact extremely useful! Thank you!
tomharto
August 8, 2018
Awesome, thanks!
Benedict Roeser October 5, 2018 edited
Today, this stopped working for me. Seems that Bitbucket removed the id from the form field and accessing it via name also doesn't seem to work. :(
4 votes
+1 for this. We like to have the user's name in the branch:
myname/PR-123-feature-number-one-two-three
It would be nice if you Let the user build their branch names with the following variables:
  • Issue Type (bug/feature/etc)
  • Epic Name
  • Username
  • Issue Number
  • Issue Description
Thus currently the setting would be ${Issue Number}-${Issue Description}, and I would be able to accomplish what I want with ${Username}/${Issue Number}-${Issue Description}.
I think that would solve it for pretty much everyone here.
Abdul
September 5, 2019
my team needs this for sure.
Phil Rittenhouse January 27, 2017
+1 for us too
By the way, everyone should check out the feature request here: https://jira.atlassian.com/browse/BSERV-8746 and upvote
Deleted user November 21, 2016
+1
Fraser Hardy
I +1 for this to be supported in Bitbucket too. We use git-flow and the missing branch type with Jira and Bitbucket is stopping us from using in-Jira branching.
Jeremy Weathers
March 4, 2014
We are also looking for this functionality with download JIRA (6.2) and Bitbucket. The branch type should be based on the issue type, so if I create a branch from a new feature or enhancement issue, the branch name would be e.g. feature/ABC-123, but if I create from a bug issue, then the branch name would be e.g. bugfix/ABC-456.
da61
August 13, 2019 edited
+1 our team could really use this feature
Anatoliy Mushtuk
December 3, 2018
+1 for configurable branch name prefix feature implementation
Kim Carlsen
September 16, 2015
any update?
Lucas Conde July 22, 2015
How can I do that? Can´t find any documentation.
Michael Feher
November 3, 2014
@Fraser Hardy A workaround for using the git/hg-flow extensions is to prefix the auto generated branch name with feature/ and your flow commands should work as expected. Cheers!
