change issue type: from subtask to another one
Andrea
Hi, I was trying to understand how to convert a sub_task to another issue kind... i'd like to ask you for help.
3 accepted
Cristian0791
December 17, 2024
Hi Andrea,
As our colleague @Mara (bitvoodoo ag)  mentioned you need to "Convert to issue"
Maybe this ss will help:
Andrea
Hi, thank you for your answer; I cannot find the 'Convert to Issue' option; also I tryed to go in personal setting but I dont know what doing then..
Mara (bitvoodoo ag)
December 17, 2024
Hello @Andrea
Please click on the sub-task and then proceed to click on the three dots (upper right-hand corner). You should see the option to "convert to issue".
Important:
You need to have permissions to set issue types within that project.
I hope this helped & best wishes
Mara
Andrea
Important:
Mmm, i was sure I was in administation role....
Mara (bitvoodoo ag)
December 17, 2024
Are you a project admin or a site admin?
Andrea
Mmmm, honestly I am not sure about what to do for verifying it....??
Andrea
mmm, from what I found by looking for information, I should go on: personal settings and switch to off: 'New Jira issue view for software projects', the problem is I cannot see that option....i just found 'Nuova esperienza di transizione dei ticket' (italian version)......could it be the rigth option ??
Mara (bitvoodoo ag)
December 19, 2024
Hi @Andrea
I think you might have the wrong administration role in this case? How's the structure at your company, do you have an option to contact a person with an higher admin role?
Andrea
I am just by my own; I am going trough Jira courses for learning purposes..
Andrea
mm
FREE
