company-managed project custom field not displaying all vaues in dropdown when editing an issue
Emma Hernandez November 25, 2024
When creating an issue, the for a company-managed project, all the 58 values are displayed in a custom field dropdown, but when editing an issue only 50 values are displayed in the same custom field dropdown.   Is there a limit on the number of values displayed for a custom field dropdown once an issue has been created?
Trudy Claspill
November 25, 2024
Hello @Emma Hernandez
Based on the following change request, it seems like the list should display up to 100 entries.
https://jira.atlassian.com/browse/JRACLOUD-83496
Thanks for your reply.  Unfortunately, I only see 50 entries and no option to scroll down further.
Trudy Claspill
November 25, 2024
I understand that Atlassian presents a truncated list to ensure better UI performance, you should have an option to start typing in an entry to filter the list and get matches that are not currently in the default visible list.
Like Emma Hernandez likes this
Trudy Claspill
November 28, 2024
Have you tried typing the entry you want, and does that filter the list to display entries that are not initially displayed?
Emma Hernandez November 29, 2024
typing the first letter of the entry I wanted worked.
Trudy Claspill
December 4, 2024
I did my own test with a selection list that has more than 50 options, and I had the same experience. In the Create Issue dialog all the options displayed but in the Edit/View screen only 50 displayed.
If the workaround of typing in part of the option you want as a means to filter the list is not acceptable, I suggest that you open a support case directly with Atlassian to find out if they changed the limit from 100 to 50 for the view/edit screen.
If you choose to do that, please share here what you learn from them.
If the workaround is acceptable, please consider clicking on the Accept Answer button to mark your Question as Solved.
Ray Hundley December 6, 2024
Just FYI we recently experienced the exact same issue.  We have a custom dropdown field with 58 values.  All values are displayed on the issue create screen but only 50 are displayed on the issue edit screen.
The typing in part of the option you want does work as a filter, but IMHO it is not a long term solution.
