compatible with Jira 6.3
Indrit December 16, 2014
This plugin is not compatible with JIRA 6.3
https://marketplace.atlassian.com/plugins/com.herzum.jira.plugin.approval.herzum-approval-plugin
How to solve this problem ??
Antonella Capalbo
December 23, 2014
The HAP version 1.1.0, compatible with JIRA 6.3, is now available.
Pedro Cora
December 16, 2014
Added a label for the add-on. :)
Nic Brough -Adaptavist-
December 16, 2014
Contact the addon author for an update.
In the meantime, your options are
  1. Wait
  2. Don't upgrade to JIRA 6.3 until a release is done
  3. Look at replacing it with other stuff
  4. If you're desperate, you could risk installing the latest version and hoping it does no damage and works as well, but I wouldn't recommend it without very extensive testing.
Orgest Koka December 21, 2014
I have JIRA 6.3 instance in my server, and this plugin is not compatible with it.
December 21, 2014
Ok, cross off option 4 then.
I am in trouble, with this addon. When will release the version compatible with jira 6.3.
December 21, 2014
You'll need to contact the vendor to find out when (if) they are going to release a new version
