configuration problem in some post-function Script Runner
Daniil Lyovkin July 30, 2014
hi,
There was a problem setting up some scripts. For example, when editing post-function I can not open the ability to customize the transition.
Yesterday everything was fine.
jira 6.3.1
Script Runner 3.0.3
Tempo TimeSheets 7.9.2
(log.txt)
JamieA
August 4, 2014
Hello Daniil. This looks similar to https://jamieechlin.atlassian.net/browse/GRV-470. I never understood what the issue was there, it's a bit of a mess because the end user could not edit the task so kept creating subtasks.
Hard to see what the connection is, maybe something to do with Cyrillic alphabet? If your log shows errors can you attach it to that issue please?
hote September 18, 2014
I met the bug too, and my environment is jira 6.3.1
The questioner means when choose post function like “create sub task” or “Transition parent when all subtasks are resolved ” , there's no place to set parameters.
Here I attached the right page and the wrong page:
image2014-9-19 12:3:32.png
image2014-9-19 12:6:2.png
JamieA
September 18, 2014
This is https://jamieechlin.atlassian.net/browse/GRV-470, and is fixed in 3.0.4.
Help us plant more trees
