context supports only CSS resources
jack January 26, 2023 edited
hi When I run the script, these errors occur, how can I solve it?
2023-01-26 15:50:30,811+0800 http-nio-8080-exec-24 WARN jin 950x1788637x1 1ipkyxy 192.168.101.1 /rest/wrm/2.0/resources [c.a.j.plugin.editor.RteDataProvider] "jira.rich.editor.content" context supports only CSS resources, please review atlassian-plugin.xml, some or is including different resource type.
2023-01-26 15:50:38,072+0800 http-nio-8080-exec-8 INFO jin 950x1788701x2 1ipkyxy 192.168.101.1 /secure/AjaxIssueAction.jspa [c.a.jira.index.QueueingIndexStats] [JIRA-STATS] [INDEXING-QUEUE] index:ISSUE, total primary queue stats: {"maxQueueSize":1,"putCounter":23,"queueFullOnPut":0,"getCounter":22,"timeInQueueMillis":{"count":22,"min":0,"max":4,"sum":12,"avg":0,"distributionCounter":{"0":16,"1":2,"10":4,"100":0,"1000":0,"10000":0,"20000":0,"30000":0}},"timeToUpdateIndexMillis":{"count":22,"min":0,"max":18,"sum":85,"avg":3,"distributionCounter":{"0":2,"1":3,"10":14,"50":3,"100":0,"500":0,"1000":0}},"totalTimeMillis":{"count":22,"min":1,"max":21,"sum":106,"avg":4,"distributionCounter":{"0":0,"1":4,"10":15,"100":3,"1000":0,"10000":0,"20000":0,"30000":0}},"totalTimeFailedMillis":{"count":0,"min":0,"max":0,"sum":0,"avg":0,"distributionCounter":{}},"totalTimeTimedOutMillis":{"count":0,"min":0,"max":0,"sum":0,"avg":0,"distributionCounter":{}},"putCounterByThreadTopN":{"http-nio-8080-exec-7":5,"http-nio-8080-exec-8":5,"http-nio-8080-exec-5":3,"http-nio-8080-exec-20":2,"http-nio-8080-exec-23":2,"http-nio-8080-exec-9":2,"http-nio-8080-exec-13":1,"http-nio-8080-exec-2":1,"http-nio-8080-exec-24":1,"http-nio-8080-exec-3":1},"indexerNotRunningCounter":0}
2023-01-26 15:50:38,075+0800 http-nio-8080-exec-8 INFO jin 950x1788701x2 1ipkyxy 192.168.101.1 /secure/AjaxIssueAction.jspa [c.a.jira.index.QueueingIndexStats] [JIRA-STATS] [INDEXING-QUEUE] index:ISSUE, total secondary queue stats: {"maxQueueSize":5,"putCounter":13884,"queueFullOnPut":0,"getCounter":13884,"timeInQueueMillis":{"count":13884,"min":0,"max":128,"sum":3827,"avg":0,"distributionCounter":{"0":12013,"1":1745,"10":87,"100":38,"1000":1,"10
Andreza Nascimento Santos October 25, 2023
I'm facing a very similar problem, the error is basically the same, but it is only caused when a user external to my organization runs the script.
Can you help me?
has been resolved
Nic Brough -Adaptavist-
January 27, 2023
Excellent that it is fixed, but could you share how it got done?
jack January 27, 2023
I changed Value type: Constant or Groovy Template to Groovy Expression and it worked fine.
