copy agile boards from one jira instance to another
Debraj neogi May 29, 2015
Is there a way to copy agile boards from one JIRA instance to another. Without someone sitting and manually creating them to the new instance?
José Marañón [Awnaba Software S.L.]
April 11, 2017
Project Configurator for JIRA permits project export and import between different JIRA instances, including boards and Agile data (on JIRA 7). Boards can also be exported/imported independently from project data.
This plugin is available only for JIRA Server .
(Disclaimer: I am part of the team behind this plugin)
David_Blau
October 11, 2018
Is this still server only?  No cloud?
Andre Borzzatto
May 29, 2015
Hi there,
It's unfortunately not possible to do it just yet in JIRA Cloud, maybe there are some available options for JIRA Server, but Cloud currently lacks the ability to do so.
It would be required for the user to recreate the project and setup the board properties.
One of the closest suggestions we have to enable a similar feature would be to include in project export/import the JIRA Agile data.:
I hope this helps!
David_Blau
October 11, 2018
Is this still the case?
