create a predefine number of subtasks
Dd
Is there a way in automation that upon a manual trigger, the automation will create 27 subtasks in a loop?
Basically I want to do the following:
Create a task called - MyTask
From it manually trigger an automation rule that will generate 27 subtasks named My-Task - Job X where X is increasing from 0 to 26.
So when completed, I will have:
Task: MyTask
  - Subtask: MyTask - Job 0
  - Subtask: MyTask - Job 1
  - Subtask: MyTask - Job 2
  - Subtask: MyTask - Job 26
March 5, 2024 edited
Hi @Dd
If you care about the subtask ordering, or each subtask has unique values, they will need to be added, one by one, as @John Funk suggests.
If you do not care about the ordering, they could be created with an advanced branch over the values.  The source of the values could be a created variable or a lookup table.
For example:
  • action: create variable
    • name: varJobList
    • smart value: Job 0, Job 1, Job 2
  • advanced branch:
    • name: varJob
    • smart value: {{varJobList.split(", ")}}
      • action: create subtask, referencing {{varJob}}
It is possible to even automate the creation of varJobList for your scenario, if you have a fixed number of issues to create.
If the number of issues is dynamic (e.g., from an issue field count) the solution is more complicated.  Here is a post describing a method to do that: https://community.atlassian.com/t5/Jira-Software-questions/how-to-use-jira-automation-to-create-multiple-issues-based-on-a/qaq-p/2443240
Dd
Is there a way to loop over all subtasks of a parent?
I noticed that cloning will clone subtasks as well, so I can just generate one such task and then clone and loop over the "new" subtasks.
I couldn't find a smart value referring to a list of subtasks
March 6, 2024
For an issue, the smart value is:
{{issue.subtasks}}
That only contains some of the subtasks fields, such as link, summary, status, etc.  To access all of the fields, they would need to be branched to or loaded from a lookup issues action.
Like • Dd likes this
John Funk
Hi Dd,
I don't know a way of creating the sub-tasks via loop. I think you will have to include a separate action for each one in the rule to create them.
Dd
Sadly, it seems that this is the case (for now at least).
Like • John Funk likes this
Ryan_Buschmeyer
We have this same issue as well.  We have certain Epics that will need Sub-task creation based on a number of weeks spanning the Epic (weekly check-ins).  Our solution was to use Zapier to loop this task.  We created a field "Number of Weeks" and then use that field to tell Zapier how many times to iterate the loop.
We also introduced a field to tell Zapier to not process this again (Zap Complete).
Hope this helps somebody.
