createIssue not able to create
vishal May 14, 2019
string project = "JD";
string issue_parent_Key = "Hey";
string issue_priority;//Possible values: "Major", "Critical" etc.
string issue_description;
string[] issue_components;
string issue_security_level;
string[] custom_fields_mapping;
issue_priority = "Medium";
issue_description = "Description of the issue";
issue_components = "My Data"; //an array containing all the components of the current project
issue_security_level = "Administrator";
custom_fields_mapping = "";
string k = createIssue(
project,
issue_parent_Key,
"Sub-task",
"Summary of the sub task" ,
issue_priority,
issue_description,
issue_components,
currentDate() + "30d",
issue_security_level,
//print ("On the project " + project + ", issue " + k + "is created.");
linkIssue(k, issue_parent_Key, "Relates");
Alexey Matveev
May 15, 2019
Is it Jira Cloud or Server? What error do you have?
vishal May 15, 2019
Its Cloud and the error unable to create Issue
Nic Brough -Adaptavist-
May 15, 2019
Could you give us the full error you are seeing?  "unable to create issue" could be all sorts of things.
Alexey Matveev
May 15, 2019
It should be a key like Hey-1
And this issue should exist.
Go to SIL manager and see the logs with the Load Logs button for errors
vishal May 15, 2019
Hey Alexey,
The issue was not existing it was deleted accidently.
