creating search field in custom field using java script
Aravind Koushik Gobburu
I created a custom field with a single-line list option and created 5000 users. In order to not waste time, I need a search bar in that.How to do this using javascript
brbojorque
Apologies but I don't understand why you have to do that since there is a User Picker custom field exactly for that reason.
January 20, 2021 edited
In the screenshot in a custom field user, there are so many users. I need a search bar so that I cant check many users all the time when I want. This is one of my requirements.
brbojorque
Hi @Aravind Koushik Gobburu ,
I've encountered this problem before I just installed this add-on below:
https://marketplace.atlassian.com/apps/1220214/select2?hosting=server&tab=overview
Please read carefully how to use this add-on.
Thanks for that @brbojorque .It is really a good solution for that. Thanks for that.
brbojorque
I would appreciate if you accept my answer so other people can find it useful.
Sure, I have done that.
Like • brbojorque likes this
brbojorque
I would also suggest for privacy reasons to remove the image you link above, usernames are leaking.
Keep in mind that this is a public domain :)
Like • Aravind Koushik Gobburu likes this
Read the story
