current version confluence
Good day! How can I see a current version of Confluence?
2 accepted
Hans Polder _Devoteam_
@Пернебаев Жалғасбек Әлімханұлы ,
From the tags in your post, it seems that you're using Cloud.
Cloud doesn't work with regular versioning, it mostly works with feature flags to enable or disable something. For reference, also see this article on Jira Cloud: https://confluence.atlassian.com/jirakb/how-to-check-your-jira-cloud-version-1272283464.html#:~:text=To%20check%20the%20Jira%20Cloud,and%20the%20build%20number%20details.&text=The%20result%20will%20be%20the,the%20version%20and%20build%20details.
Why would you want this information? If it would be because you're actually using fConfluence Data Center, then you should be able to observe the version at the bottom of the screen: https://confluence.atlassian.com/confkb/how-do-i-know-what-version-of-confluence-is-running-179441565.html#:~:text=If%20you%20don't%20see,to%20see%20the%20version%20number.
If you want the version number because you are actually on the Cloud-version, but are reading documentation about Confluence, make sure to switch it back to the 'Cloud' option as this is always updated and not dependent on a specific version of the application.
Ollie Guan
Register today
