×Hello any one,
I would like to change one of my custom field name color to red. Could you please assist how to make it?
Shanmuk
Hello @Shanmukha Teja Badana ,
Please check this post as it might answer your question. As a workaround if you want an easier and in-built solution, you can add a red description under the field name to highlight it. Go to the field configuration of your project, edit the custom field description :
<span style="color:red"> ... </span>
Hi @Shanmukha Teja Badana - Did you ever get this solved?
I will mark Antoine's response as Accepted for now - let us know if you still need assistance.
