Hi. İ have custom field where I have many lines (about 250 and groun up). How to search in this field? I cant found that field types whith search. Also like see in internet I cant order that lines by names f. e. - only eah line by line. May be there have order by option?
Hi Kamil
Go to the Advanced Search and put in something like:
"Field Name" ~ "some text"
Where Field Name is the exact name of your field. And some text is the value you are searching for.
@John Funk thank you for answer. You understand me wrong. I whant to search in list .
for example I have list
test 1
test 2
test 250 and I whant if write the name for eample test 23 - the list give me that name. Search in component dosnt work - dosnt know why. Also there not order by option. How I can make order by for this list.
