custom fields with formula
unnikrishnan
I would like to introduce a custom fields that ca derive the data based on a calculation with the help of other 3-4 custom fields .
Would that be possible in JIRA ?
Callum Carlile _Automation Consultants_
What sort of data is involved with the fields? Are they all numbers, or are there some strings involved?
unnikrishnan
Only numbers.
If there's only numbers, then you have a few options.
There's Abacus which lets you calculate values and set the field values of other fields based off these calculations.
There's also Automation for Jira Lite where you can set up easy-to-configure automation rules, and with this lite version you get 300 automations per month, after that you would need to upgrade to a paid version
unnikrishnan
Thanks for the update.Do we have any option without the paid plug-ins ?
@unnikrishnan I have had a look around the marketplace and I don't believe there are nay free add-ons for what you are trying to achieve, nor are there any built-in functionalities within Jira that allow you to do this
unnikrishnan
Okay. Thanks Callum.
