×Hello Community
I am stuck with a scenario. Please help me. I have a custom field type : Label in my issuetype Epic. Name of Label (customefield is) : Additional IDs.
Scenario
User is expected to enter minimum 1 and maximum 10 Ids into the field and each entered Id must be 8 Characters long only. If user enters more than 10 Ids, an error should be shown on the screen. If user enter an Id which is not equal to 8 characters should throw an error on the screen as user updates epic.
I have Scriptrunner installed on my jira server edition.
Please advice me how to implement this constraints on the field.
Thank you .
Anupam
You can add a Validator of type Simple scripted validator [ScriptRunner] with a Condition like this:
import com.atlassian.jira.issue.CustomFieldManager
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
CustomField myCustomField = customFieldManager.getCustomFieldObjectsByName("Your Custom Field Name")[0]
boolean allValidLength = true
int numLabels = 0
issue.getCustomFieldValue(myCustomField).each{
numLabels++
if(it.toString().size() != 8){
allValidLength = false
return numLabels <= 10 && allValidLength
And an Error Message like: Each Additional ID must be 8 characters in length, and there must not be more than 10 of them.
Thanks for replying and help @Payne
I am not sure at which status I should add this validator. I have large workflow with more than 10 statuses. User wants check should be in place at screen and irrespective of status of Epic.
Anupam
In a situation like this we have put a validator near the beginning of the workflow when the issue is created and one more near closure. Think about when the user will provide those IDs and go from there.
