Hello i'm having somes trouble with JIRA software, when I go on localhost:8080 it show me this error
"JIRA — Internal Server Error
Error reference: 50f0b4ff-9b56-40ab-917c-f9efb816a271
Unable to render full error details at this time. Please consult the error logs for more information."
While looking in the log file I've found this :
"2016-06-17 15:19:53,886 http-nio-8080-exec-2 ERROR [NoModule] Could not determine database type.
org.h2.jdbc.JdbcSQLException: File corrupted while reading record: "C:/Program Files/Atlassian/Application Data/JIRA/database/h2db.mv.db"
Can some one help me ?
best regards,
Yes, the database is damaged. I'm afraid your best option is to go and find the last backup, or rebuild your test system from a production one.
Are you running JIRA from sdk? You might want to try with different start-up options (bump up the JIRA version a patch version or two) or try a previous known sdk version.
Okay thank you
