database monitorin link didn't work
Nairi salma April 22, 2022
Hi
when using database monitoring link , an error occured:
An error occurred whilst rendering this message. Please contact the administrators, and inform them of this bug. Details: ------- org.apache.velocity.exception.MethodInvocationException: Invocation of method 'getGraphs' in class com.atlassian.jira.plugins.monitor.database.MonitorDatabase threw exception
Michael Wolfe
July 14, 2022
I recently ran into this issue working with a client, and running the install_fontconfig.sh in /bin fixed the issue for us.  We were also seeing a notice about fonts not being installed as well in the environment, which was also resolved.
https://confluence.atlassian.com/jirakb/health-check-fonts-965568867.html
Brant Schroeder
April 24, 2022
@Nairi salma Did you recently upgrade?  What is showing up in the logs, same error?
Nairi salma April 25, 2022
Hi @Brant Schroeder
yes we recently update jira , il the log we have the same error
hi
issue solved by changing native java used by Jira
Matias Vivas June 7, 2022
pls can you give more details? how do you do it, for which version of jira? to which jre?
Nairi salma June 7, 2022
Hi
this problem is solved by changing default jdk used by  8.22.2 jira  version
thanks
my jira 8.22 comes with jre 11.0.13, which version you propose?
Nairi salma June 15, 2022
we didn't use the default jre provided by jira
we installed oracle jdk 11 on the system and changed JAVA_HOME on setenv.sh to point to new JDK
this solution solved all issues related to jre ( plugin starting, Fonts, database monitoring ...)
atlassian, dance, gamification, badge, razzle dazzle, team '25 anaheim
Earn a one-day badge today and do the Atlazzle Dazzle! 🕺
Today only! Share what you’re the most excited about for Team ‘25 or just dance out the beginning of a new quarter with us.
Comment the post
