HI,
I have a number field named "previous time spent", and i want to calculate the difference between this field and the timeSpent field. Using automation.
I tried to write :
{{issue.timeSpent}}-{{issue.customField_10076}}
where issue.customField_10076 : is the field that i've created
but it's not working : it writes me only the timeSpent !
please i need help ! thanks
did you check the output of value in your custom field?
i've fixed the problem.
The cause was that i had to use the math expression {{#=}}....{{/}}for the smart values
exemple :
{{#=}}{{issue.Invoice Amount}} * 1.2{{/}}
cool.
Hello, is this working also to calculate the resolution time of the tickets? For example the time between the creation time and the time the ticket was set as Resolved. I have followed the steps :
1. Create custom field (date time picker type or number type, tried with both of them)
2. Tried this with the following formula, but it is not working..
{{issue.solved.diff(issue.created).days}}
Any idea which might be the problem? I am using Jira server
