disable fix version/s inheritance
Andris Grinbergs
January 21, 2021
I would like to disable Fix Version/s field inheritance for one project between issue and sub-task. Is there any solution to this? When I try to update Fix Version/s field in subtask it flips back to the value set in parent issue.
KAGITHALA BABU ANVESH
January 21, 2021
Hi @Andris Grinbergs ,
Good Day ...!
In my  Test project.
1. created a version 1.0, 2.0
2. Created a story(TEST-1) and add fix version as "1.0"
3. Then created a sub-task for (TEST-1) as (TEST-2).
4. The Fix Version is set to "None" in Sub-Task (TEST-2).
5. Edited the sub-task fix version field and I'm able to update it to "2.0".
In my system, we don't have automations. But as @Nic Brough -Adaptavist- suggested , I think parent and child can't have 2 different Fix versions.
Thanks.
January 21, 2021
No, there's no way to turn this off.  Sub-tasks are always considered to be part of their parent issue, it would not make sense to have a version different to that of the parent.
SERVER
Register now
