do not inherit components when creating subtasks
Michael Aglas June 12, 2016
This question is in reference to Atlassian Documentation: Configuring sub-tasks
Hello we are using JIRA 6.3.7 with according JIRA Agile Plugin installation. I recognized that when creating a subtask of an issue the component field is inherited from parent, which is undesired behaviour. I guess this is implemented in JIRA Agile, when switching plugin off everything works as expected, while switched on the component field appears with same components as parent issue. How to remove this behaviour? Is there any setting to do so? Or do I really need to write a script to remove components in case it was left blank on creation?
Michael Aglas June 14, 2016
ok with a postscript I can prevent such behaviour, but it is so weird behaviour... the agile plugin allows to copy values from parent to child, why implementing such behaviour hard coded - make s no sense
Mahesh S
June 12, 2016
This is not a default behaviour in JIRA. Please check the post function in the create step of the child issue's workflow. I believe, a post function will be present to inherit the component value from the parent. Kindly delete it if available.
There is not post-function for it existing in the workflow. As I wrote: it seems to be JIRA Agile plugin.
Mahesh S
June 12, 2016
Okay, agreed! The JIRA agile is copying the basic system fields (such as Component(s), Priority, FixVersions,etc..) from it's parent task automatically. Its mentioned here: https://answers.atlassian.com/questions/260020
Luckily, I believe the fact is that, JIRA is copying these fields only if it is left empty. Please confirm this.
If it is true, we can add a post function to clear these fields if not required.
Michael Aglas June 13, 2016
this is true... but I want this field to be optionally be filled by the user. So it can be left empty at the beginning and the function group, processing this subtasks, will enter affected components, which are collected at main issue... I don't need components be inherited, since it will confuse the users.
Mahesh S
June 14, 2016
so, you found a workaround? smile
it's not nice, but yes
Mahesh S
June 14, 2016
May I know how you have done this?
I used groovy script executed in subtask postfunction of create transition:
this checks if the components are empty, if yes it explicitly sets component field to be empty
in any other case I don't touch component field, so it will take already entered components on create screen
this does the trick
I first checked for components equal to parent, but that doesn't work out
Mahesh S
June 14, 2016
That should be appreciated. I believe scripted field along with validation is the only solution.
