docker hub image dbconfig.xml has incorrect permissions
Adam Collins August 20, 2019
/var/atlassian/application-data/jira/dbconfig.xml seems to be owned by root instead of the user jira when pulling the latest docker image atlassian/jira-software:latest (8.3.2)
Is this correct? it prevents the installation completing with a permission denied error
Shannon S
August 22, 2019
Hi Adam,
I think that's not right. I would recommend running through How to fix JIRA Directories permission in Linux and correcting your permissions. Let us know if that helps.
Shannon
Adam Collins August 22, 2019
I know "how" to fix the error... the problem is that because it is part of the docker image, whenever I restart the container or pull a fresh install, it is broken.
I need to manually change the permissions and docker commit the image to prevent it getting reset when the docker container is restarted. This is also related to
https://community.atlassian.com/t5/Jira-questions/Jira-docker-container-recreates-dbconfig-xml-when-restarting/qaq-p/1158438
Learn more
