×In 2023, we would use JQL fixVersion = earliestUnreleasedVersion to give us the Issues for the next Release. Now in 2024, no results return for this JQL. I have proof there are Issues by manually keying in the Release for which I want to see Issues. Did something change with earliestunreleasedversion?
To confirm you are using this JQL function as documented: https://support.atlassian.com/jira-software-cloud/docs/jql-functions/#earliestUnreleasedVersion--
The "earliest" unreleased version is the one at the bottom of the version list, when viewed from the Release page. It does not use any date fields set in the versions.
Is this how you are also using this JQL function and versions?
The image you are showing is not a view of the Releases page from the project.
Please navigate to your project, and the Releases page (from the left of the page) and you will see the release ordering. That may explain why the function is returning no issues: it may be matching to another version than what you expected.
