easy binary installer using postgres or mysql not hsqldb
Zippy Zeppoli June 27, 2012
Is there a way to use the easy binary installer to install the bundled tomcat / jira install but use mysql or postegres instead of hsqldb?
Rodrigo Girardi Adami
August 4, 2013
Hi Zippy,
After you install confluence with the binary installer, you can hit confluence in the browser, put the license over there, and choose between evaluation or production. As you choose production, you can select the database which you would like to run confluence with.
More information can be found here and here.
I hope this helps!
Rodrigo
