eclipse 2019 plugin
Dan Cosio October 25, 2019
Does anyone know if there is a compatible jira plugin for eclipse 2019. I can't find the atlassian plugin when searching market place and when using the using the update sites from https://confluence.atlassian.com/ideplugin/atlassian-connector-for-eclipse/installation-and-upgrade-guide-for-the-eclipse-connector/installing-the-eclipse-connector
they are all incompatible with eclipse 2019
Thanks Jack, so if there any type of integration with jira and eclipse?
Jack Nolddor _Sweet Bananas_
Any, as far as I know.
Hi Dan Cosio,
Atlassian IDE Connectors were discontinuing on 2015 as you can see in the We are discontinuing the support for Atlassian IDE Connectors article.
Regards
