error: JIRA could not attach the file as there was a missing token. Please try attaching the file again. It happens on Google Chrome today.
This happens when there's a network error, or timeout. The easiest way to replicate it is to leave the computer for a while and then try the action - your tokens expire. Sometimes, it can happen when you're trying to upload too large a file as well.
Have you tried it again yet? If you did, what happened?
"leave the computer for awhile and then try"
OMG, so let's define "awhile". A minute? An Hour"? A day?. Do I leave the computer and go sit in another room or do I have to leave the building? Or can I just throw a blanket over it so it thinks I left. Maybe I could leave it at Atlassian headquarter and they could fix it.
Priceless.
No, that is clearly not what I said.
Please try reading the answer properly and thinking about it in the context of the question that was asked, instead of being silly.
Hi Nic, I was wondering what you'd advise if a user has experienced the same issue in multiple browsers, using various different files and a number of different tickets? Cache has been cleared, the user has logged in and out of JIRA...nothing basic seems to work.
And she didn't leave her machine for a while either...literally fired up a new browser, logged into JIRA, tried to attach a file...and got the same error.
Hi Nic ,
you are right that is a timeout err , just refresh the page and perform the operation .
it worked.
thanks!
After refreshing the page couple of times it works for me.
I too had the same issue, while uploading some very small files (< 50kb). Tried multiple times and did not get uploaded initially.
Then, I simply refreshed the page and attached it again. Worked.
I had two tabs open to JIRA. All I had to do was refresh the given tab and there was no more token error.
I read the first answers above, and refreshed the tab after writing a long defect report—and lost the whole thing.
I despise stupid problems like this, and they seem to be all over atlassian software.
Sorry, just venting.
Could it be that people have Confluence open in another tab and and it's overwriting the JIRA cookie?
Logging into another Atlassian application logs me out of Confluence
I doubt the case, because I never run Confluence. None of them listed here work. Any resolution from Atlassian?
logout from jira and login again. That's Solution
..only if it would work! In this case it's an "it also doesn't work around"
Any new information on this? I just encountered it while testing JIRA 7.13. In my case, this was while trying to attach a file in the "Create Issue" screen. There's no way that I know of to "refresh" that dialog - so I completed the Create process and attached it later - but my users aren't going to like having a field for attaching documents for submission and seeing that error. It's just a wee bit off-putting.
+1
We've just started getting reports of this issue happening in Chrome on version 7.13.8. No Jira updates or changes to the network stack recently.
A tab refresh seems to allow the user to complete the current operation, but they're reporting that they're seeing the issue multiple times a day and having to refresh each time to get around it.
Interestingly, users are reporting that the issue seems to go away when they use Firefox.
Almost 4 years since the first response in this thread and it still hasn't been fixed. I am currently using Chrome Version 83.0.4103.116 and can't upload a file that is 758KB without the token error. Tried the wait, logout/login/refresh..... What will it take for this to be rectified.
Happens again and again.
For several independent users, on several independent circumstances.
Tried with Screenshot Copy-Paste, tried with "Add attachment"
Many users write a long detail, then the token expires in between and they can not do attachments anymore. If they'd refresh: all is lost and they have to start from scratch.
I do not want to write them an instruction document how to create a ticket, like "open a word file, add all information into the word file, then create a ticket and simply attach the word file.
Long Story short:
Yes, the Token may expire eventually. But: is there a way to lengthen the time of expiration? Is it Chrome (Browser) or JIRA (Atlassian) to "fix" that? Any suggestion of a workaround (despite to "refresh the browser from time to time")?
Why does it take two hours to write an issue?
The Jira team are looking into a solution where the token is refreshed on copying and pasting.
For now the workaround would either be to download the images you need off the original ticket and then insert them via file upload. Or refresh the source ticket before copying and pasting images over.
All the best
Owen
I also faced the same issue, I just refreshed the page on which I am trying to upload a file(excel) and re-uploaded the file and it worked for me.
This can also occur if you are trying to drop an attachment on an issue that has an open comment. Simply select Add to close the comment and the attachment should work.
Refresh the browser page and retry attaching the attachement.
That works!
For me, I changed the file format. I was trying to update a png, but when I updated a jpg of the same file it worked fine.
Refresh the tab works !
Logout from jira and login again.
Refresh worked for me here as well.
Well, I might as well add my voice that I can't attach a file in Chrome while using Jira 7.2.8 (no Confluence, no one overwriting my cookies, just plain broken)
BTW, works fine in Firefox.
I'm encountering the same problem today on Chrome when I try to attach an image or excel file to a bug in jira. I am not running Confluence.
This is happening to me in Chrome. Did anyone ever find an answer?
For me too "Happening in Chrome even though "Block third-party cookies..." is disabled."
this is happening when login to JIRA from Confluence space shortcut link.
this is not due large file or session time out, this could be bug.
How is this an acceptable answer? "This could be a bug"?
Someone accepted a useless and wrong answer here, so people stopped paying attention.
Have a look at where Ann and I give useful answers.
Just happened in Chrome as well...
This happened to me today on Firefox (50.1.0). Earlier today, I cleared my entire Firefox history/cache/cookies/etc. My network is fine and the file is only 392k.
