error when setting story points from epic view, customfield_10014
Willem D'Haeseleer
March 13, 2024
Getting this error when attempting to set the story points for a story from the epic details view
We couldn't set the story point value
Field 'customfield_10014' cannot be set. It is not on the appropriate screen, or unknown.
setting the story points from the story details view does work and reflects accurately on the epic view
John Cobbs May 13, 2024
Had the same issue.
Story Points was missing from the edit screen. Adding it back solved the issue for me.
Tobias Kuechen
August 27, 2024
same issue here - please fix
Trudy Claspill
Hello @Willem D_Haeseleer
I have not been able to replicate your error.
Does this happen to all users?
Have you tried a different browser or a private browser window?
Willem D'Haeseleer
March 13, 2024
This issue also occurs in chrome private mode and safari.
Trudy Claspill
Does it happen for other users?
Are you working with issues in Company Managed project or a Team Managed project?
Can you confirm that 10014 is in fact the ID associated with the story point field?
