export project from bitbucket got exception in Java
vasili_svirski
September 30, 2013
On export project from bitbucket got:
An error occurred whilst rendering this message. Please contact the administrators, and inform them of this bug. Details: ------- org.apache.velocity.exception.MethodInvocationException: Invocation of method 'getCurrentStepName' in class com.atlassian.jira.plugins.importer.bitbucket.web.ReceiveOauthCodePage threw exception java.lang.ArrayIndexOutOfBoundsException: -1 at
AgentSmith
September 30, 2013
It seems that you've encountered a bug. Check out https://jira.atlassian.com/browse/JRA-34965.
Note: This is being blocked by https://ecosystem.atlassian.net/browse/JIM-1041, which fortunately has been fixed but not yet deployed to production.
Unfortunately, there is no workaround at this time so I recommend you consider voting and leaving your comments on https://jira.atlassian.com/browse/JRA-34965 and add yourself as a watcher so you recieve updates.
Hope this helps!
Heath
Looks like this is Soaking before being deployed, any idea how long that will take. Is there no other way to sync Bitbucket with Jira?
Help us plant more trees
