extract certain keys and values from change
Samar Elsayed June 15, 2021 edited
Hi
I am using the below in a scripted field
changeHistoryManager.getChangeItemsForField(issue, "status")
which is returning the below  :
[com.atlassian.jira.issue.history.ChangeItemBean@4cbf004a[fieldType=jira,field=status,from=10002,fromString=In Development,to=10009,toString=Blocked,created=2021-06-12 01:06:52.792], com.atlassian.jira.issue.history.ChangeItemBean@1c19d69c[fieldType=jira,field=status,from=10009,fromString=Blocked,to=10184,toString=In Design,created=2021-06-12 01:07:05.427], com.atlassian.jira.issue.history.ChangeItemBean@785e386e[fieldType=jira,field=status,from=10002,fromString=In Development,to=10009,toString=Blocked,created=2021-06-12 01:35:41.529], com.atlassian.jira.issue.history.ChangeItemBean@4ee968a0[fieldType=jira,field=status,from=10009,fromString=Blocked,to=10008,toString=Done,created=2021-06-12 01:36:08.516], com.atlassian.jira.issue.history.ChangeItemBean@7a608c67[fieldType=jira,field=status,from=10008,fromString=Done,to=10021,toString=Cancelled,created=2021-06-12 01:37:32.262], com.atlassian.jira.issue.history.ChangeItemBean@289f1881[fieldType=jira,field=status,from=10002,fromString=In Development,to=10009,toString=Blocked,created=2021-06-12 01:42:44.575], com.atlassian.jira.issue.history.ChangeItemBean@218bc8b4[fieldType=jira,field=status,from=10009,fromString=Blocked,to=10184,toString=In Design,created=2021-06-12 01:43:02.087], com.atlassian.jira.issue.history.ChangeItemBean@2422184d[fieldType=jira,field=status,from=19123,fromString=Requires Design,to=10184,toString=In Design,created=2021-06-12 01:56:11.607], com.atlassian.jira.issue.history.ChangeItemBean@5a5fbb1a[fieldType=jira,field=status,from=10002,fromString=In Development,to=10009,toString=Blocked,created=2021-06-12 02:04:08.493]]
I need to know how I can extract only the fromString and toString and their values and save them in a list/map in the same order they appear above.
the list I mean is like for example :
[[fromString=In Development, toString=Blocked ] , [fromString=Blocked, toString=Cancelled ] ]
Max Lim _ScriptRunner_
June 15, 2021
You can use following snippet to return a List<Map>:
changeHistoryManager.getChangeItemsForField(issue, "status").collect {
"fromString": it.fromString,
"toString": it.toString
thank you! @Max Lim _ScriptRunner_
one more question :
how can I remove consecutive duplicate values that fit this condition and only keep one of them :
keep any transition that has In Development  and remove the duplicates in the transitions where from and to are anything else other than In Development
so for example here is the list  :
[[fromString:Ready for Dev, toString:In Development], [fromString:In Development, toString:Blocked], [fromString:Blocked, toString:In Design], [fromString:In Design, toString:Requires Design]]
and after removing the duplicates that fit the condition :
[[fromString:Ready for Dev, toString:In Development], [fromString:In Development, toString:Blocked], [fromString:In Design, toString:Requires Design]]
June 16, 2021
Are you saying you only want values with "in Development" in "fromString" and "toString" keys?
You can do this:
}.findAll {it.fromString == "In Development" || it.toString == "In Development"}
Samar Elsayed June 17, 2021
No not find , I mean something like unique values of from and to together based on a condition like :
( it.toString != "In Development" ) && (it.fromString != "In Development" && it.toString != "Backlog" && it.toString != "Ready for Dev" )
so for example in this  list  :
we have 2 consecutive elements that fit the condition which are :
so unique should return one of  so in the end, it look like that :
June 17, 2021 edited
I not sure if I understand your condition. To apply only on consecutive items, I think you have to use a for loop to achieve that.
Perhaps, the toUnqiue(closure) or toUnique(comparator) methods could achieve this too.
