Hello everyone,
I have a problem and wanted to ask for advice: I have a field in which a table is contained. Through an automation and a regular expression I fetch words, but I noticed that it also fetches the table and cells in which the words are contained not only. Is there any way to fix this and only fetch the words?
Hi @FrancoB
Welcome to the community.
Look at this community request. Tis was recently raised and resolved.
I think it is similar to what you are requesting.
Hi @Marc - Devoteam
thanks for the link it was really helpful to me.
Through this I was able to do partly what I needed to do:
{{issue.description.match(“(?<=\Start:\|)([^|]+)”)}}
I just have a problem that the word I need to search for “Start:” is sometimes written as a hyperlink and therefore is not considered.
Unfortunately I import the text from an email and it contains formatting, I also tried converting it .text but unfortunately I find that the word I need to extract Ex. Home is written under the word Start: and so even then it doesn't work, like this
Start:
Home
Hi @FrancoB -- Welcome to the Atlassian Community!
IMO, the match() function in automation rules does not consistently handle things like text containing newlines, and other formatting. As a result, it can terminate the searching earlier than expected.
A workaround for that is to first replace all the newlines before the match attempt:
{{issue.description.replace("\n", " ").match(your expression)}}
And when the newlines are needed for later processing, they may be first replaced with a known value, and then set back later. For example:
{{issue.description.replace("\n", "~~~").match(your expression).replace("~~~", "\n")}}
