filter - using a wildcard searching project
Melissa Brady June 7, 2019
In the filters I want to search for all projects beginning with GIS
Examples:
GIS - Storymap
GIS - Parks Landuse
I am using
resolved > -14d AND issuetype = Milestone AND status in (DONE, Done) and project = "GIS*" ORDER BY created DESC
and its not working.   what am I doing wrong.
Petter Gonçalves
August 14, 2019
Hello Melissa,
Indeed, it's not possible using only JIRA JQL to search for projects containing a specific string, but only using a third-party app like Script runner as mentioned by @Alexander Bondarev.
That being said, we have a feature request to get it implemented here:
Allow wildcard or '~' symbol to search for project/category name in JQL
Feel free to vote and watch the suggestion to increase its priority and also receive notifications about any updates.
Alexander Bondarev
June 8, 2019
is it clear that you want search by 'project'?
it seems to me, that you should change it for 'summary'.
also you should change '=' to '~',try this jql :
resolved > -14d AND issuetype = Milestone AND status in (DONE, Done) and summary ~ "GIS*" ORDER BY created DESC
Melissa Brady June 8, 2019
When I change it to ~ it says
Error in the JQL Query: The character '*' is a reserved JQL character. You must enclose it in a string or use the escape '\u002a' instead. (line 1, character 89)
And yes it’s the project field not summary.
Alexander Bondarev
June 15, 2019
@Melissa Brady , do you haveScriptRunner for Jira
Look through Script JQL Functions - Regular Expressions - projectMatch(reg exp).
Check it please:
resolved > -14d AND issuetype = Milestone AND status in (DONE, Done) and project in projectMatch("^GIS*") ORDER BY created DESC
Like Ben Admin likes this
Lexi
@Petter Gonçalves - we see the same error when we try to wildcard search on the summary field. Do we need script runner for that as well, or is it just the project field that this shouldn't work for?
We want to find summaries containing arch*
I get The value 'GIS*' does not exist for the field 'project'.
