groovy script help
Debraj neogi November 30, 2015
in a post-function, what's the syntax for a Condition (groovy expression) that basically says "Dev Assignee field is empty” (and must to be true for the post-function to apply)?
Phill Fox
You can use the following formula to check if an assignee field is empty and combine with other actions.
if (! cfValues['Assignee']) ...
Jamie Echlin _ScriptRunner - The Adaptavist Group_
So for a condition on a post-function, for a custom field called Dev Assignee, it would be: cfValues['Dev Assignee'] that should be all that's required
Can you add the plugin tag otherwise people won't see this...
