help to multiply value of 2 custom fields in Automation
sarema
February 10, 2022
I have a Team managed project in JIRA.
It has 2 list type custom fields - Impact and Probability, which have numbers in the dropdown.I would like to multiply the selected value of the 2 custom fields and save them in another field (Score)Score = Impact * Probabilty.However, I am unable to make this work using Automation and Smart Values. Please help! Thank you in Advance.
3 votes
Cat W
You can multiply two fields in Automation using (Field1 smart value) * (Field2 smart value), but you'll want to make sure you're surrounding your expression with {{#=}} {{/}} so that Automation recognizes it as a math expression.
Here is what the final expression should look like:
{{#=}}{{issue.Field1.value}} * {{issue.Field2.value}}{{/}}
So based on the fields you listed, you should be able to use the following expression to set the Score field in the Edit automation action:
{{#=}}{{issue.Impact.value}} * {{issue.Probability.value}}{{/}}
Cat W
Side note, for future reference @sarema if you create a post as a question rather than a discussion, it can help others who might have similar questions find answers more easily.  :)
Josh Costella
What @Cat W said!
