Would anyone be willing to share the steps necessary to change my existing hierarchy from Epics -> Stories to Epics -> Features - > Story
1) I changed the hierarchy type to 1) epics, 2) Features
Do I need change / update the Issue Type Schemes? Or, Do I have to buy an app that will give me this structure?
thanks
Welcome! This is the details about how you can change issue type hierarchy: https://support.atlassian.com/jira-cloud-administration/docs/configure-the-issue-type-hierarchy/
This would be a change that spans the system.
But the other element that you should think about is using the "Parent" field functionality, which brings together some flexible chaining of hierarchy.
