Hi;
I'm using Jira Software Cloud
I can only export in xml, RSS, Word and excel CSV.
Is there a way I can add HTLM for example? or normal excel?
Thanks a lot
Those are the only options available on Cloud (unless you get Apps to add more).
For info, the Excel option was removed a couple of years back, in favour of CSV, as everyone wanted CSV instead.
Hi but I do have the Cloud....
My issue is that when I export from Jira to csv the epic link shows as Jira ID and not as a name
For JIRA Cloud, there is no built-in feature to do that. Spreadsheets can read CSV's. But there are many add-ons in marketplace.
Btw, please take a look at JRASERVER-61891.
