how can I add a custom field into all screens
Abner Severino
February 6, 2020
hi community , I created a custom field , but I need to know how can adde it this field into all screens without select screens one by one...
in addition to the above is possible that when create a new project this fields appears automatically into their screen?
thanks a lot in advance.
Satvik Sharma
Figured out some JS that works (on Cloud at least, not tested on Server) to run on the page to check all the boxes.
document.querySelectorAll("input[name=associatedScreens]").forEach(input => input.checked = true)
Nika
March 23, 2022 edited
on Data Center, visually it works but no field is visible when creating the task
UPDATE
Re-index fixed everything
Satvik Sharma
Hey @Nika this trick is for the /secure/admin/AssociateFieldToScreens!default.jspa route where you are associating fields to screens.
Like Nika likes this
Rahul Jodavula
October 1, 2024
Mark Northcott
You can go in to associate field flagged to screens and select all screens.
Unfortunately that does not help with any new projects or screens.
Renni Verho
We have also quite huge amount of screens and sometimes new custom field needs to be added many screens and finding and clicking one by one is quite pain.
Idea for quick improvement: add "select all" in screen selection view.
Cody Stevens
February 6, 2020
Hey @Abner Severino
You may be able to write something with ScriptRunner but from my research it doesn't look like you can. Looking into their Script Listeners, you cant watch for when a project is created or a new screen is made and that would be the only way I can think of with ScriptRunner to do what you want.
Being in cloud limits your options with this. Referencing this post but In Server you could set up a listener and then use the REST API to modify the screens. Cloud unfortunately does not have listeners.
I hate to say it but I don't think this is possible.
