how can I have in backlog are a third block of issues?
jeimi garcia lopez February 13, 2025
Im trying to build a Kanban board with different columns.
When I have a backlog (hide from the Kanban), the next column and state is To Do. well, this state is showed up in the backlog section (in the top), so ok for that.
I was thinking to put another status like "triage" between backlog and To Do, but backlog don't show up, just in the case I add a column and this one is the first on the board.
I even added the state to the column together with to do, but only show the name of the column and don't create another "block" inside
¿How can I solve avoiding to create a second board?
Jack Brickey
Hi @jeimi garcia lopez , it sounds like you are asking to create different "rows" or sections within your backlog. Is that the case? It isn't currently possible to create 'sections' in the backlog. This has been requested in the past and you'll find several similar posts in the community. I know that there has been more than one request made but if I recall, they were closed as won't fix.
Exactly Jack, is that what I was looking for.
So If Atlassian didn't develop that functionality.. :(
Learn more
