Hi there!
Once you start a sprint it's not possible to deactivate it, the best you can do is to complete the sprint.
Here's the doc that explains how to end the sprint:
https://confluence.atlassian.com/display/AGILE/Ending+a+Sprint
Hope it helps!
I think you can remove all issues from sprint ,then you can delete the sprint in plan model
