there's an announcement feature in the project that presents to the end users as a banner. Can I access previous announcements?
I am trying to figure out how many announcements we've added in the past, the cadence, etc.
Hi @Jane Nguyen
As per knowledge the previous banner content is not saved anywhere.
Only the present content is visible.
Vikram P
Hi @Jane Nguyen, my response is specific to Data Center. I am not sure if it is the same for Cloud.
If you are asking how to see all the announcements you have acknowledged as an end user, you would do the following:
If you are asking as a system admin, all past announcements should still be listed under Administration --> Manage Apps --> Announcer Dashboard, unless someone deleted them.
