how can part of label be used for filtering?
frans vervuurt October 27, 2021
I use labels to relate epics/issues related to a project. Therefore, I label them "project_XXX" or "project_YYY" or "project_ZZZ". (Epics/issues can also have additional labels.)
I want to get an overview of all epics/issues related to a project, so filtering something like: label contains "project_". Can this be done?
Alternatively, can labels be included in an excel export, so I can filter in excel??
Mohamed Benziane
October 27, 2021
frans vervuurt October 28, 2021
Hi Mohamed,
Thanks a lot for your response.
This does not cover what I look for.
I need to filter on labels containing specific text, like "project_" in the example above.
In your example, filter on labels containing "test".
Or: can I export all information including labels to an excel and do the filtering there?
Frans
Mohamed Benziane
October 28, 2021
This functionnality is not supported for this field. So you will need to export them and make some formula in excel. Look at Jack's response in the thread below :
https://community.atlassian.com/t5/Jira-questions/How-do-I-find-all-labels-in-Jira/qaq-p/1784796
frans vervuurt October 29, 2021
Hi Mohamed,
Thanks again for your answer.
I checked the export with Jack's response, and I think I will manage.
So, solved :-)
