how do I access the jira database
muysz
January 4, 2017
This question is in reference to Atlassian Documentation: How to unlock a Locked field
Ask your question here...
Jonas Andersson
January 4, 2017
If you look for and in dbconfig.xml you will see hostname, username and password for the database, then select the right client and simply connect.
Fabio Racobaldo _Herzum_
You need to have a DB client installed and, using db user/password in your dbconfig.xml file, access db. Then you can go ahead with instruction of the follwing article https://confluence.atlassian.com/jirakb/unlock-a-locked-jira-software-custom-field-779158866.html
Fabio
Aleksandr Zuevich
January 4, 2017
you need to install a DB client depending on your DB (PgAdmin for PostgreSQL, MySQL-Front for MySQL, etc.) and connect to your DB.
Register now
