×I believe my velocity report is throwing this error because I have a test sprint that has no stories.
"No issues present in sprint to generate scope change model"
How Can I remove the sprint??
Hi Robert,
My bad, the sprint wasn't deleted after it's closed, yes the documentation statiing -
""Closed sprints cannot be deleted." is correct
People facing similar issue here (see comments)
https://confluence.atlassian.com/display/AGILE/Deleting+a+Sprint
Can you confirm that having a closed sprint with no stories will cause the Velocity Chart to throw this error:
For this reason I'm trying to remove the closed sprint but so far I've been unsuccessfull.
i just tested a similar scenario in my test machine, it works fine at my side. I am using JIRA Agile version - 6.3.6.1
Which version are you using? there is a known issue as well -
Please be more specific.
What is it that works fine for you? I'm trying to remove a closed sprint (with no stories) so that my Velocity Chart stops throwing this error "No issues present in sprint to generate scope change model"
I'm using Jira v6.0.5
I was able to remove a completed sprint which didn't have any issues.
you have mentioned your JIRA version but the bug is with the JIRA Agile (greenhopper) version whose link i shared
My bad Jira Agile Version: 6.2.5
How did you remove the closed sprint?
The documentation link that you pasted above clearly states ..."Closed sprints cannot be deleted."
