how do I import a csv file into an existing Jira project.
Vidya VASUDEVAN
I see while importing the csv file , it does not give me an option of existing project , instead it gives  the choice of new project. I want csv file to be imported for my current project.
Does Atlassian have this feature by any chance.
Vidya
Bob Dalm
February 4, 2025
Hi Vidya,
Select Settings (⛭) > System > External System Import on the sidebar, then "Switch to the old experience". You'll be able to select a project.
Best,
Bob
Vidya VASUDEVAN
https://europassistancetest.atlassian.net/jira/settings/system/external-import
Can you guide me what is Old experience, I have attached the page and it does not give me any other option . It gives me the option of creating new project but not in the existing project considering the mapping settings.
Bob Dalm
February 5, 2025
This should be fine. Select CSV:
Choose your CSV file;
Select the project where you'd like to import the issues to;
Good luck!
Vidya VASUDEVAN
Hi Bob, this was really. I was able to do the steps as per your guidance but landed in the below page .. Can you guide me for the below step if possible. It gives me an option of Map field in which the options are : choose the field but when I select it does not give me further next option
https://europassistancetest.atlassian.net/secure/admin/CsvFieldMappingsPage!default.jspa?externalSystem=com.atlassian.jira.plugins.jim-plugin%3AcsvImporter
Bob Dalm
February 9, 2025
Hi Vidya, happy to have a look if you share a screenshot :)
