how i set jpg default value in jira custom fields?
serap_ileri April 13, 2023
Hi there,
I want set an image defalut value in text custom field. I change my renderer to wiki styles but its not working.
How can I do this? Is there any way ?
Best Wishes,
Arun Unnikrishnan
June 14, 2023
@serap_ileri
I also had same requirement for one of the project. I was able to achieve the same by following this link : Text Formatting Notation Help
In the Custom Field Default value, you need to add the URL as per the format said in the above link.
Hope it helps!
Daniel H. Fisher April 19, 2024
when you state, "I was able to achieve the same by following this link : Text Formatting Notation Help," what do you mean by "achieve?"
Help us plant more trees
