When a sub-task is created in a JIRA issue card, a brief preview of the sub-task is shown.
Currently, the sub-task card shows the number, summary, assignee, and status. How can I make other fields visible in this preview as well?
Hello @구본석
If you are referring to the list of subtasks that appears in the details view of the parent issue, then it is not possible to customize that at this time. There is an open change request for that to which you can add your vote:
To make sub-task previews different in JIRA, you need to change card layout settings on board. First, go to your board and find the three dots (or maybe it looks like a gear) at top right corner. Click there and choose "Board settings." From that place, choose "Card layout." Additional fields can be added to the sub-task preview by picking the fields you wish from the dropdown menu. Save your changes, and the sub-task cards now show extra fields you chose.
