Sign up Log in
how to change a required field to optional when creating an issue , using SIL langage in Power scrip
ichrak_djebrit November 28, 2023
Anna Hryhoruk _Appfire_
November 28, 2023
Hello @ichrak_djebrit ,
It`s important to know how the field is set to be required in your system: using Power Scripts functionality or Jira native configuration. In case it`s done via Power Scripts it can be a validator/condition on transition, or Live Fields script so if that`s the case please share such script you currently use. But if you configured a field to be required via Jira's user interface using the "Required" link associated with that field, I don`t think we can make it optional via SIL script. As a workaround, we can add some default value to that field on the Create issue.
Please add more details about your current setup and maybe we`ll find some options.
Best regards,
Anna
Thank you for your response, @Anna Hryhoruk _Appfire_ , actually it is a system field and it is required by default in the sytem (Summary) so i can't change it to optional in the configuration of that field, so i need a solution for this, (i'm thinking about using SIL langage  but i didn't create a script yet),
"The idea is that i want to create  an issue with optional summary field "
November 28, 2023
@ichrak_djebrit , unfortunately, it`s not possible to make a summary field optional in Jira. It is always a required field, and the only workaround I can suggest is to add some default value to it on the Create screen using Live Fields from Power Scripts. Please check this page, it describes how to set default values for system fields on the Create screen. The summary field is not a part of the example, but it can be used there in the same way as the description field.
Best regards,
Anna
SERVER
